b18a into 91si hatch
what all do I need to do to swap in a b18a into a 91si hatch. like what parts and modifications and stuff. also about what should I be paying for this
man i cant tell you what you need but I LOVE MY B18A 91 HATCH you prolly will too , it pulls so hard, with my i/h/e i pulled a 9.73 1/8th and i am still learning to race my car
well you will either need to learn how to rewire or get the adapter.
Second full swap with axles and engine wiring harness.
Third mounts and new shift linkage
Fourth Some know how!
<--b18a being built and going to be in a 91 civic hb std!
i am pulling the motor out of his car, what all should i take? I am also getting the tranny, everything's there. can i use the mounts that are there? I have friends that are gonna help put it in when it comes to that, i just need to know what to take from the car
Rotorphile.
Take everything you can, incuding everything attached to the engine and transaxle, along with the axles, engine harness, computer, etc.
wooooo woooooooooo
wtf are you guys talking about? You need the engine, tranny, ecu, axles and aftermarket mounts. Use your stock Si harness on the b18, and plug in the ecu. You will need to modify the b18 shiftlinkage by adding in approx 6 inches. You will have to bash down the lip on the rear subframe so the mount clears, and you will also have to dent the frame so the alternator pulley clears. If you get a 3 mount kit, you'll have to flatten out the front mount, or cut it off. A 4 mount kit will bolt right in.
the guy was saying he doesn't wanna give up the axles, or at least not yet. cause he doesn't want it to not be rollable. are axles expensive?
