fuel pump question for swappers
What fuel pump should I be using for my B16 swap, the 90-93 Integra or the 94 Del Sol VTEC fuel pump? ...or is there a different one? I'm not sure I need a new one but my engine is still running funny and there's not much else I can do with it. It does run rich even at 8200 rpms with my D15 fuel pump.
Rob
Rob
Let me tell you about swapping fuel pumps...I just did mine...go ahead and buy a H.O. unit like the Walbro, I swapped pumps which included dropping the gas tank and 2 hours later I'm done. It isn't THAT hard but I don't care to do it again but since I went with just a so so pump it won't be large enough when I spray...just decide your goals and buy once. You'll be happier.
GWAKS- Tech Geekifier
FYI: most stock honda fuel pumps are capable of supporting 200 HP as long as they're in good shape, however, if you doubt it's durability, then go ahead and upgrade.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
I won't trust ANY 10-15 year old fuel pump made to run a SOHC non vtec now supporting a B16A and then I'm gonna spray it on top of that. If you buy the pump for a 92-95 Civic (if it's not offered for the CRX) you can change the pump out and use all the factory components. Like I said, I have to drop my tank again and put a bigger one in there
Quick Silver
S2000
2
11-14-2006 05:24 AM
chinahanji
Vehicle Classifieds
06-09-2006 09:32 PM
