cruise control
cruise control
hello,
I plan on installing cruise control onto my car, a 1991 civic std hatchback. Can anyone direct me towards informational sites on how to do this. I plan on using all factory stuff as much as possible. IE cruise buttons on dash, and on steering wheel, also allowing the dash light to come on signaling use of cruise control.
Any info is appreciated. Parts lists are great, etc
If this is a pain in the arse, i want to know, although i figure it would be a lot easier to install a goofy aftermarket one with a piggyback controls for you windshield wiper arm, but it would not look as nice, nor as clean. Low key is the trend, less is more.
thanks a lot
thanks a lot
Its going to be hard to get the buttons on the steering wheel.
You may want to go with the stalk mount.
Dash mount units are just hard to control. Avoid it.
Basically, you are piggybacking the throttle cable, and you will have a vacuum resevoir that works off the vacuum on your car unless you get an electric operated unit.
