? on crx rear seats.
Z20 H8R
rear seat dilema?
ok i have a chance to order a set of jdm crx rear seats..only thing is are these plug and play? can you just bolt them right into a stock crx. i have an hf so there was only a compartment back there. i havent looked to see if there is holes or not for the seatbelt harnesses...has anyone else thrown the rear seats in thier rex? was it hard? thanks
ive known of ppl making their own seats with alot of custom fabrication but never of someone bolting in jdm seats? good luck regardless if u end up ordering them, the are tiny with no leg room, i prefer my crx without a rear sear, extra ppl means my car goes slowly, 1.6 liters have no torque to begin with
alright, the usdm crx has three compartments directly behind the driver and passenger seats. there are two small ones on the side, and one larger one in the middle.
the jdm rear seat replaces the larger compartment in the middle. you will need the jdm replacements of the two smaller compartments, as the seatbelts get fed through those. aside from that, i believe you need the bracket to mount the seat.
also, make sure it's an actual jdm seat, and not one of those hideous knock-offs they sell on ebay...
Z20 H8R
its a complete ef8 rear seat set. its 400 but i dont know bout the bracket. ill have to ask. so with the belts ive seen them through the pockets but i figured they had to bolt to something? surely they wouldnt only run a rear seat belt only through the plastic? is it even plastic? does anyone have a pair of these seats? let me know.
Whoa they have knock-off jdm seats on ebay? I've seen one or two of them where they include the seat belts too.
