mini me help.... y8 mani, injectors, and head on a d15b (dx)
To anyone who has done this or has experience with it. Can you use a y8 head with the y8 intake mani, injectors and fuel rails on a dx crx? I read somewhere that if your going to use the z6 injectors that you dont need the resistor box from the 88-91 si's Is this the same with the y8? I was planning on doing the dx to si conversion and then setting up the mini me (leaning towards using the zdyne one wire ecu)
Any info would be much appriciated.
