New alternator; not starting
I replaced a bad alternator in my 88 DX yesterday. I took my battery to get recharged today when i took the old core to advance. i got home, installed the battery, and now the car won't start. it does nothing.
the alternator job was simple. after getting the old one out, i put the new one in and reconnected the green plug and the black wire. i put the belt on, and tightened it when i tighened the alternator's bolts. the battery is fully charged. what is going on? before i did this, it would at least turn over. what am i missing? anything i can check? the only odd thing i've noticed is a beige plug (with one orange wire and one black) that isn't plugged in. i'm pretty sure this was how it was when i began work on the car--i don't remember disconnecting it. please help...i'm at the end of my rope here.
It's my first day.
the belt is too tight or too loose, maybe?
i had my belt so tight once on my s10 that the truck wouldn't start cuz it couldn't turn the belt. i didnt even tense it that much.
you also didn't mention any symptoms, you got clicking, interior lights, NOTHING, is it turning but not starting?
eh?
eh?
i get nothing when i turn the ignition. no clicks, nothing. also, before i swapped out the alternator, and my battery was really low, i still had interior lights and stuff. now everything is dead, with a fully charged battery. i really don't get it. everything is secure. i don't have a repair manual, and have very little experience, so i don't even know what i'm looking at. it's time to order from helms, i guess. thanks for your help.
Rotorphile.
Originally posted by excitid
check to make sure you got the cables on the right sides + to + and - to -.
i'm sure the battery is connected correctly. as i said, i did start to connect it in reverse, but when it sparked, i immediately disconnected it and reversed the connections. do you think this could've damaged parts of my electrical system?
i will check the fuses tonight. thanks again, for the help.
Rotorphile.
