New alternator; not starting
Old 09-02-2003, 01:53 PM
glueslabs
glueslabs's Avatar
ummm...what's the worst that could've happened? i only touched the negative lead to positive terminal for an instant. i know, i know. dumb mistake.
Old 09-02-2003, 01:55 PM
Fujiwara Takumi
It's my first day.
Fujiwara Takumi's Avatar
worst? eCU blown.
check your fuses all over though, under the kicks and in the engine bay.
Old 09-02-2003, 07:49 PM
glueslabs
glueslabs's Avatar
ok, guys...some good news: i found a broken fuse under the hood. i replaced it and i now have power. she even started! now the bad news: after starting it up, the engine ran super high. my idle sounded like i was doing 30. also, a large amount of white smoke flew out the exhaust. ??? i turned it off and waited a minute, then tried again. same thing. i quickly turned it off again. so what did i do now? could the alternator belt have something to do with this? as i mentioned earlier, i'm not sure about how tight it is. i just made sure it was good and taut. how can i make sure it's right? anything else to check? should i try driving it? thanks again, folks...you've been a huge help. and remember: rookie mistakes come mainly from rookies.
Old 09-02-2003, 08:35 PM
Kai
Rotorphile.
Kai's Avatar
Sounds like your electricals are roasted. Alt belt tension shouldn't do that.
White smoke sounds like water or coolant in the engine.
Old 09-02-2003, 08:39 PM
glueslabs
glueslabs's Avatar
thanks, kai. but i'll take a second opinion. : ) anyone?
Old 09-03-2003, 06:06 AM
1stGenCRXer
GWAKS- Tech Geekifier
1stGenCRXer's Avatar
Start first by adjusting your idle down to a sane level. Smoke from the rear isn't an immediate concern unless it never stops.
-Harry
AIM: NDcissive
Old 09-03-2003, 10:14 AM
glueslabs
glueslabs's Avatar
how do i adjust the idle for this car? : )
Old 09-04-2003, 03:30 PM
glueslabs
glueslabs's Avatar
any clues on the idle? my helms repair manual is on its way, i swear.
