Code 15
{1}—PGM-CARB.
{2}—PGM-FI four cylinder engines.
{3}— D5Z1 engine except California.
Code
Probable Cause
Faulty ECU.
HO2S or Oxygen sensor or circuit.
2
VSS{1}
HO2S or Oxygen sensor or circuit.{2}
3
MAP sensor or circuit.
4
Vacuum Switch{1}
Crank angle sensor or circuit.{2}
5
MAP Sensor or circuit.
6
Coolant temperature sensor or circuit.
7
M/T Clutch Switch Signal{1}
A/T Shift Position Signal{1}
Throttle angle sensor or circuit./Throttle position sensor {2}
8
Ignition Coil Signal{1}
TDC positioncrank angle sensor or circuit.{2}
9
Crank angle sensor or circuit./
#1 cylinder position
10
Intake air temperature sensor or circuit.
11
Faulty ECU.
12
EGR system failure.
13
Atmospheric pressure sensor (BARO sensor) or circuit.
14
Electronic Air Control Valve or circuit. {1}
Idle air control valve{2}
15
No Ignition output signal. Possible faulty ignitor.
16
Fuel injector circuit.
17
Vehicle speed sensor or circuit.
19
Lock-up control solenoid valve (auto trans. only)
20
Electric load detector. Possible open or short to ground in ECU wiring.
21
VTEC spool solenoid valve circuit.
22
VTEC oil pressure switch circuit.
23
KS
30
A/T control unit and ECM fuel injection signal "A"
31
A/T control unit and ECM circuit. Fuel INjection signal "B"
41 Heated oxygen sensor heater circuit.
43 Fuel supply system circuit.
48 Heated oxygen sensor circuit D15Z1 engine.{3}
Code
Probable Cause
Faulty ECU.
2
VSS{1}
3
4
Vacuum Switch{1}
5
6
7
8
9
10
11
Faulty ECU.
12
EGR system failure.
13
14
15
16
17
19
20
21
22
23
KS
30
31
