how to break crank bolt?!?
Old 08-25-2003, 09:19 AM
Fujiwara Takumi
It's my first day.
Fujiwara Takumi's Avatar
Originally posted by mullinator
I've heard of folks using the starter to break the bolt. Put a breaker bar on the bolt, with the handle resting on the ground. Then bump the starter until it comes loose. -scott '85-6 Si
seeing as the motors in hondas run backwards this trick will work with EVERY OTHER CAR other than h/a. on this car it will over tighten the bolt, and if youre anything like me, you'll snap it in half:
Old 08-27-2003, 02:27 PM
crxb16er
crxb16er's Avatar
ouch
Old 08-27-2003, 02:53 PM
Fujiwara Takumi
It's my first day.
:werd:
all is good now though.
Old 08-30-2003, 04:07 PM
krustindumm
krustindumm's Avatar
I had the same problem, I gave up and took the car to a mechanic
-Dustin
Old 08-31-2003, 07:35 AM
WhiteRice
WhiteRice's Avatar
My bro used a breaker bar. Then put the end of the bar on jack and pumped the jack till the bolt came loose. Of course, the engine was out of the car so it was a tad easier to do this way, as opposed to it still being in the car.
Old 08-31-2003, 08:15 AM
Fujiwara Takumi
It's my first day.
with it out of the car i took the starter off and jammed the back of a channel locks in the flywheel, than i had my dad put a breaker bar on and jumped on it. it came off pretty easy.
in the car is another story :happysad:
Old 09-06-2003, 09:09 AM
Redlinerz
Redlinerz's Avatar
How about while it is in the car? What is the easiest way?
Old 09-06-2003, 09:10 AM
Fujiwara Takumi
It's my first day.
well i would say if i have to do it again i will either buy or rent an impact capable of 300+ ft/lbs.
i heard that mexican zone has a tool that makes it pretty easy though.
Old 09-06-2003, 01:22 PM
Redlinerz
Redlinerz's Avatar
where and what is mexican zone????
Old 09-06-2003, 02:37 PM
Fujiwara Takumi
It's my first day.
www.autozone.com
