Is it worth adding an intake to a STD?
I have a 90 STD 4sp Hatch,
is it worth getting an intake for it?
Will it even increase performance on a car that makes a measly 70hp?
I'm thinking about getting one of the ebay cheapies, for the noise it makes if nothing else.
opinions?
E
opinions?
E
ah the good old days of my std! all i did was but a K&N cone filter on the end of my stock intake rubber thingy..u could notice sme diff in the sound at high RPMS but thats it...
Nadene will Return
its up to you man?? what kinda plans you got for it?? if you plan on doing a swap then you could get a decent one now that you can use on both engines (if applicable) or just wait for the swap, or just get something cheap and easy.
there will be a slight increase though
Re: Is it worth adding an intake to a STD?
opinions?
E
opinions?
E
http:/www.teamdelsol.com/
has a great "do-it-yourself" link for making your own. Go to their "information" section and then to their "how-to" section. This is the guidline that I will be using for mine. Very very sooon
Good luck
Jason
Thanks Magik,
I like the idea of making my own intake, so I think I'll give the Del Sol directions a try.
I'm not planning on doing a swap....not unless my engine dies for some reason. I don't race or anything. I'm more interested in gas mileage and reliability than speed. I think an intake, tint, wheels and clear corners and a console and I'll be done.
E
E
Rotorphile.
All an intake is going to do to that car is:
1) Make it louder, and
2) Make it slower.
An aftermarket intake is most likely going to be a lot bigger then your stock intake pipe, so you will loose a lot of air velocity with a huge bottleneck in the throttlebody/intake manifold area. It's just like putting an intake on a 92-95 CX, there is just no reason to because the rest of the intake/exhaust line is already so small.
If you want the look and the sound, go for it. It won't do anything else for you (on the stock STD engine at least.)
2) Make it slower.
Thanks Magik,
E
Thanks Magik,
E
Snap up a pic or two of your STD and let us have a look.
Jason
