Ok... This may sound dumb...
Old 08-07-2003 | 04:55 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
how did you swap coolant hoses without coolant spilling all over?
i know nothing about the coolant system
Old 08-07-2003 | 06:37 PM
Kai's Avatar
Kai
Rotorphile.
Do it "mad quick, yo!"
Really, you can't. Just burp the cooling system when you are done.
Old 08-08-2003 | 06:39 AM
Caster Troy SI's Avatar
Caster Troy SI
bye ashley, hello leah
Originally posted by jfiedler
i know how kindly his engine will take to little metal shreds...
it'll go :angry: :angry: :angry: :angry: :angry:
actually it'll be more like
:eek3: :eek3: :eek3: :eek3:
:jawdrop::jawdrop::jawdrop::jawdrop:
:upset: :upset: :upset: :upset:
wned: wned: wned: wned:
(each cylinder)
Old 08-08-2003 | 08:09 AM
s1ngle's Avatar
s1ngle
How do you do that?
Old 08-08-2003 | 08:33 AM
Pete's Avatar
Pete
Civilian
Ok, the filter is installed. How the hell does that thing work anyway? I just don't see how it's supposed to keep water from getting into my engine.
Old 08-08-2003 | 08:41 AM
s1ngle's Avatar
s1ngle
question: if some coolant leaked out and i just reconnected the hose without burping, is that bad?
Pete's Avatar
Pete
Civilian
oh shit... I just posted in the wrong thread... But I might as well just explain it than. I'm talking about a CAI bypass valve.
Old 08-08-2003 | 10:44 AM
Kai's Avatar
Kai
Rotorphile.
How do you do that?
Run the car with the rad. cap off and the heater on full blast until it fully warms up and the thermostat opens. Any air in the system will bubble up through the radiator opening. Top off with coolant. Opening the bleeder screw helps (when the engine is cold, close it before running the car!)
Yes, the car may run hot or actually overheat if enough coolant is lost.
