8200 gauges
8200 gauges
I am looking for gauges for a b16a crx. I want white gauges with the speedo to read 140+ and i want the tach redlinin at 8200 since im gettin a b16. The only problem is i havnt seen gauges made for a crx with an 8200 redline. I saw plenty for 99+ si since they come with a b16a in them but I dont know if they will fit into a crx. Does anybody know were i could get a gauge cluster with 8200 redline that will fit into a crx. Thanks
Nadene will Return
you can get a JDM CRX cluster.. the SiR in japan had a b16, so the rpm gauge would be accurate. whoever, the speedo is in KhM.. but i think the speedo goes to 140-160 (if it was converted to mph).
thats the only thing i can think of for this to work for you... good luck :thumbup:
or you could hook up the gauge cluster from a 90-93 integra GSR...go the 4thgenerationcivic.com they have a write up on how to do it...i used their site to put an 88 si cluster in my 91 dx so i would trust them...the only hard part would be fitting a "gauge surround" around it...hope i helped
Junior Member w/Fries
again, no idea if that's possible.
Rotorphile.
Originally posted by jfiedler
dunno if this would work...but maybe swap a USDM speedo into the JDM cluster?
Originally posted by static
Im still tryin to seach around to see if aftermarket civic si gauge clusters or gauge faces will fit on a crx
