has any1 done a D15B2 to D16Z6 mini-me swap??
Old 07-12-2003, 12:35 AM
jung4g
Asianalize your car
jung4g's Avatar
Hey, I thought you couldn't get a new head... I'm gonna have a spare z6 head, just cleaned out real well, I'll also have a spare z6 intake manifold complete that you'll need for the mpfi conversion, all you'll need is a valve cover, and a PM6, and to run like 6 wires, including an rpm switch, and later I'll chip your ecu to work with everything you've got...
Jung
Old 07-12-2003, 04:49 AM
FourthGenHatch
I'm RICK JAMES, bitch!
FourthGenHatch's Avatar
Keep in mind the Z6 is OBD-I and Y8 is OBD-II. So you will have some wiring to do. I know you can use A6 injectors and distributor but I have also heard that the distibutor timing has to be adjusted a whole lot, possibly as far as it can go just to run right. Not sure if that is true or not.
Old 07-12-2003, 10:51 AM
ZiviCase10287
RacinMasonC
ZiviCase10287's Avatar
not true, either have the 2 side bolts with big washers holding it on, or the bolt closest to the front end on and the top bolt with big washer connected, it works either way.... the z6 has about ~20-22 more hp and it has a better torque curve. the mini-me swap is not as easy as it sounds... it would be easier just to do a motor swap... be sure to have ALL the tools, sockets, screwdrivers in handy and keep track of them! (took about 3-4 hours of our time looking for parts) and get a new intake mani gasket... and maybe exhaust mani gasket depends on how good its in. overall it took me and 2 other friends 10 hours to do it ourselves.... 3-4 hours with trying to find tools, 1 hour for parts (napa gave me wrong gaskets).... good luck.
Old 02-26-2005, 06:32 PM
watdaheo504
watdaheo504's Avatar
hey can any1 help me out... i just got a 94 civic hb and the engine is gone .. well and i got my hand on a 95 civic ex engine with the code D16Z6 (with tranny).. the one in the HB is D15b7... i was wonder what need to be change and what can be kept... i know that i prob need an d16z6 ecu.. and how many wires i need to run?.. is this is simple swap or complicated one.. or is there any website with steps or instruction to do this swap?.. thanks
Old 02-26-2005, 07:31 PM
ED9man
driver
ED9man's Avatar
Originally Posted by Kai
Mini-me (n, US Slang)-
Honda D-series SOHC VTEC cylinder head bolted to any SOHC non-VTEC D15 or D16 block. The heads most commonly used are from the D16Z6 or Y8.
Some people try to claim a VTEC-E head (D15Z1) can be used to make a mini-me, but that is not correct as the VTEC-E system works differently then a standard VTEC system.
You look that up in the Webster dictionary? :chuckles:
I can't find it, maybe my edition is a little dated.
Old 02-27-2005, 08:50 AM
Kai
Rotorphile.
Kai's Avatar
It was accepted for the '06 edition. Wait for it. :db:
