What am i goin to do!?
Old 07-02-2003, 05:39 AM
Caster Troy SI
bye ashley, hello leah
Caster Troy SI's Avatar
Default What am i goin to do!?
now, what should i do with this thing? i f-ing love it. i'm realizing the potential. i having fun driving it. i'm getting ready to paint some panels and parts on the interior. i'm getting a paint job last. not sure what to do with rims(kinda old!). torn between keeping a/c and having to fix it or loosing it to loose weight. engine... i want a bigger one, but don't know which i should get. it's got a banging system, 2 twelves and 1000 watts. it's got suspension. it's got lights. it's got greddy exhaust. lemmy know what you think, the sooner i figure it out the sooner i can pimp it out.
File Type: jpg
Caster Troy SI
here's a side
File Type: jpg
Old 07-02-2003, 05:40 AM
Caster Troy SI
engine
File Type: jpg
Old 07-02-2003, 05:44 AM
Caster Troy SI
here's a better one of the inside
File Type: jpg
Old 07-02-2003, 05:45 AM
Caster Troy SI
here's one of the back
File Type: jpg
Old 07-02-2003, 07:03 AM
matt j
midwest corn killer
matt j's Avatar
built b18b (LS) with a T04e turbocharger FMIC stand alone fuel management, bigger injectors, 255lph fuel pump, more suspension, oh and paint the FMIC black so nobody will suspect it, and you wont catch theives eyes
Old 07-02-2003, 08:08 AM
Caster Troy SI
ok... b18b is a motor, a t04e is a turbo, fmic is ?, more suspension? what do you mean more suspension?
Old 07-02-2003, 08:11 AM
Caster Troy SI
oh... and how much trouble am i goin to have with finding, and installing the motor and turbo?
Old 07-02-2003, 09:48 AM
matt j
midwest corn killer
matt j's Avatar
front mount intercooler, suspension i mean struts, bushings, sway bars, strut bars tie bars, and a good set of springs (little stiffer in the rear) and then corner balance the car.
car is already mpfi just do a b18a (obd0) swap ecus, get a rev hard manifold, zdyne gold ecu, and then build the piss out of the motor and put in new injectors and pump. you will have to get hasport mounts and shift linkage
Old 07-02-2003, 10:00 AM
jung4g
Asianalize your car
jung4g's Avatar
Yeah, a turbo LS motor is pretty cheap power... Ditch those rims and seat covers, ugh...
Jung
