WEIRD idle-CHECK engine HELP!
ok my rex is acting weird. my friend put a 90 sI motor in my 88 Hf and it idles funny. when i start it it will idle right above 1000, and will continue to do so for maybe 5 minutes. then, as ti warms up it will usually drop to about 100 when im in neutral. when i stop at lights n stuff it barely stays alive, and if its hot outside will almost always die on me. and then sometimes it will idle at 1000 too but mostly right at about 100. im thinkin maybe the o2 sensor, because i checked the ecu and it just blinked once, but my friend said if nothing is wrong it will always blink once. or maybe the eacv, but i dont know how to take it off n clean it, or even WHERE IT IS! SOMEONE HELP ME PLEASE!!
Rotorphile.
FYI:
Code 1 (one short blink): Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
Code 10 (one long blink): IAT Sensor (Intake Air Temperature)
I'm RICK JAMES, bitch!
Actually it is probably your EACV (Electronic Air Control Valve) its on the back of the intake manifold and it keeps your idle at a steady level of 800, so if its not at that I say it is probably your EACV.
Rotorphile.
I'm wondering what it's really idling at. It's not possible for a piston engine our size to idle at 100RPM, it will stall out and die before it turns that slow. Even a rotary can barely do that.
oh extra hot days...it will idle at about 1100 for maybe 6 seconds, then fall to right above 0, the battery light will usually flicker on and off as well as the oil light, and id say about 70% of the time it will die. if it doesnt die, it will juss sit above 0, BARELY idling. Also when i gas it sometimes, i heard a popping noise, and, lets say when im driving in 4th, and i let off the gas, i heard popping noises coming from my exaust. any info.
oh the ECU code was one SHORT blink. So what should i do?
Rotorphile.
Have you tried a new ECU? Maybe yours is baked. The popping sounds like you are running rich, do you smell gas in the exhaust?
(*disclaimer* I do NOT endorse actual exhaust sniffing as it may KILL you if you sit there long enough )
bye ashley, hello leah
my crx is popping when i'm in gear and let off the gas and my rpms are at around 3 to 4 grand, and yes i smell gas in my exhaust. cough cough. also not much, but when i get on the gas black smoke comes out of the exhaust. well... i guess a bunch cuz the entire back of my car has like soot on it, and i wash it ever 3 days and it gets covered in soot in that amount of time. how can i learn why it's running rich?
yea mine does the exact same thing! it pops when i let off the gas and this smell fills my inside, like fuel or oil or someting. how can i fix it if its funning rich. and the idle is still funny, with a check engine light coming on. it only dies tho on hot hott days. any help!
