5th Gen Gauge Cluster Question ? (longish)
Old 06-17-2003 | 10:30 PM
Jafro's Avatar
Jafro
I'm made of meat!
Default 5th Gen Gauge Cluster Question ? (longish)
I picked up a gauge cluster from a 93 vx hatchback in the junkyard today for $12. I don't know if it's going to work in my car or if there's any info already available about swapping different civic model gauge clusters.
I have a 92 cx with a 92 dx engine (D15b7). I retained my original engine wiring harness during the swap, of course the interior harness is untouched. I replaced the P05 ECU with a '92 P06 ECU and upgraded the engine harness to a 4-wire o2 sensor so it would work right with that ECU, but other than that, nothing has been changed. Everything works except the shift light. I guess what's most important about all that is if the interior wiring harness has provisions for this gauge cluster.
My cx has a 3" temperature gauge where the vx has its tach. I'm willing to part with my 100k old cx cluster for this 342,042 mile old piece to avoid buying an aftermarket tach. I cut the harness for the vx cluster just to be safe in case I needed to change wires around or if I needed reference. I'd just like to know if it works before I tear into my dash because I broke the hell out of the cluster's surround panel (black plastic thing with the vents in it) while taking the cluster out of the donor car, so I don't want to destroy mine trying this if it's not going to work. Any tips on non-destructively getting my cx gauge cluster out of the dash would be appreciated. I know about the two screws, I just couldn't get it to pry loose without breaking.
Do the clusters have the same plug-in connectors?
I know the engine harnesses have different #'s of wires, but the pin-outs and even the wire colors are the same, but I don't know how Honda treated the chassis. Are the chassis harnesses the same for 5th gen hatchbacks?
It would be totally sweet if it were just plug-&-play. Somehow I don't think it will be that easy. Will there be a tach signal wire already on my cx harness or will I need to tap one somewhere?
Also and assuming a vx cluster would work, since the speedometers are identical on either one, is it possible to remove the speedo gauge assemblies and swap them between the clusters so I could keep my 100k old odometer? 342,042 is just ridiculous, but big-ups to the previous owner! That's really impressive.
Thanks in advance for any help. And thanks again for the space.
Jafro
If it ain't broke, it's not mine.
Old 06-17-2003 | 10:40 PM
Jafro's Avatar
Jafro
I'm made of meat!
Very sorry. I posted this in the wrong forum. Please kill this thread.
Old 06-18-2003 | 06:56 PM
Kai's Avatar
Kai
Rotorphile.
before it dies, in case it hasn't been mentioned yet, the 5G uses an electronic VSS so the speedo won't work.
