proper procedure for clearing DTC's from ECU
What is the right way to erase the fault memory on the ECU? I know I'm supposed to pull a fuse or fuses, but which one(s)? I've heard that I can pull either the clock/radio fuse, OR the ECU fuse. Will both of them erase the fault memory?
Do I pull the fuse with the ignition turned on? or off? Will it hurt the ECU if the fuse is pulled while the ignition is on? Hopefully someone knows this. Thanks
nah in order to reset the ecu u either pull the hazard fuse under the hood, its like a 10 amp fuse (red) or just disconnect ur battery for 30 seconds. that will reset everything.
