questions!
questions!
ok i just fied my massive leaking and overheating problem by installing a new thermostat. i also just got the wiring harness totally revampe new fuel pump and a few otehr goodies.... well this morning i got out and drive my car and as i pull up i get out and look under the car and it is dripping coolant off of the passanger side of the block.. when i look over head of the motor there is some collant sitting on the lip above the B16A marker on the motor and it runs down the side of the motor.. im guessing my upper radiator hose is loose?? any suggestions any thoughts?? also im going to clean the crap outof my car today.. any little tuning tricks you might have in mind?? also is there anothe way to controll my ide speed other than the screw on the itnake manifold on the top???
thanks guys!
thanks guys!
I'm RICK JAMES, bitch!
Hose could be loose, go check it out. Or you could have a hole in another hose. But I'm sure if you replaced all that stuff the leak is a very minor problem.
seems to be mostly just coolant.. but the engine was sputtering likethe gasket had let some unwanted mixing take place so ive decided to not run it untill i replace the gasket.. i gotta call honda today and order a replacement.
thanks for the help
thanks for the help
93CivicSiD16HB
92+ Civic/EL & Del Sol
17
02-04-2006 09:35 PM
93CivicSiD16HB
18
01-27-2006 09:00 AM
h00nter
2
06-19-2002 10:00 AM
