spark plug question!!!!!!!
I was gonna put in some new spark plugs and i noticed that there was oil where the spark plugs go. What could this problem be??? My friend told me it could be a busted valve cover gasket. Is this very expensive to fix???? need help!!!!
GWAKS- Tech Geekifier
Not very expensive, you just need to replace the seals on the spark plug tubes and the valve cover gasket while you're at it.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
yah just pick up some rtv silicon and remove ur valve cover, you will have a gasket that u can reuse and when u do clean it all up and then put dabs of silicon over the 4 individual spark plug holes and redo ur valve cover gasket with more silicon when u put it back on. Peice of cake let me know if ur still wary doing it but once u open it up its self explanitory while uve got the valve cover open clean it up and remove any crud and sticky deposits in there itll make ur car run a little better if uve got lots of crud
