brake ques. for 1stGenCRXer
Old 02-13-2003, 01:28 PM
spdzone
spdzone's Avatar
Default brake ques. for 1stGenCRXer
I was thinking of changing out the front rotors to cross drilled or slotted, not really sure what would be best. I'm planning to auto cross sometime in the near future. Also, is it possible to change the rear drums to disc? BTW, I have an 85 CRX.
Any help I greatly appreciate it.
Thanks
Old 02-13-2003, 01:48 PM
GreenMachineREX
Banned
GreenMachineREX's Avatar
check out www.fourthgenhatch.com he has a :how to: change rear drums to disc...
Old 02-13-2003, 01:55 PM
MrFatbooty
Wannabe yuppie
MrFatbooty's Avatar
Cross drilled or slotted doesn't matter, you don't need either one. A set of fresh plain rotors and some good pads will be fine.
Doing a rear disk swap is totally different on an '85 than on the newer cars with an independent rear suspension. You need to swap in a rear axle from a first generation Integra.
Old 02-13-2003, 02:25 PM
spdzone
spdzone's Avatar
thanks for your help. I contacted HAPrecycling in Rancho Cordova, CA. They have the full rear disc conversion for $250. Sounds good to me. It comes with all the mounting hardware, hoses, cables, and new pads.
Old 02-13-2003, 02:58 PM
1stGenCRXer
GWAKS- Tech Geekifier
1stGenCRXer's Avatar
Do they have a website?
Edit: found it
-Harry
AIM: NDcissive
Old 02-13-2003, 06:09 PM
WhiteRice
WhiteRice's Avatar
Slotted or cross drilled rotors......is it for cooling purposes? Is there any other reason to get them? never dealt w/them before.
Old 02-13-2003, 06:12 PM
spdzone
spdzone's Avatar
i don't know either. when i go to the races I see them everywhere. they must serve some kind of purpose.
Old 02-13-2003, 06:16 PM
1stGenCRXer
cooling and giving the gas venting from the brake pads a path to go without interfering with braking performance. With modern performance brake pads though, it's totally unnecessary and just takes away surface area that could be helping to slow you down.
-Harry
AIM: NDcissive
Old 02-13-2003, 06:19 PM
WhiteRice
WhiteRice's Avatar
That is what I would think. Just by using common logic.
Thanks!!
Old 02-14-2003, 05:13 AM
FourthGenHatch
I'm RICK JAMES, bitch!
FourthGenHatch's Avatar
Yeah modern pads don't release a lot of gas so it's sort of pointless.
