Power Steering
Old 01-28-2003, 07:49 PM
Creep
Creep's Avatar
Originally posted by 1stGenCRXer
It doesn't freeze, but it can absorb water, which would freeze. Sounds like the latter is part of your problem, blocking off a return line which forces the power steering pump to push fluid like crazy. I'd start by doing a flush and fill of your power steering fluid.
okay i'll try flushing it.
Old 01-28-2003, 07:50 PM
Creep
Creep's Avatar
Originally posted by Bakeoff
Mine does the same thing in the cold. It just gets really stiff from the cold. As long as the pump still turns and you're not burning up the belt, it's all good.
Sometimes it's just stiff, but others I can't drive it because the
wheel is locked all the way to the left.
