steering wheel removal, attn forthgenhatch....
for that added pep
ok just got my MOMO and wanna put it on this weekend but dont have a wheel puller. do i really need one? is there any way to get it off w/o one
forthgenhatch howd u get the mugen on?
I eat paint chips.
I know you posted this to forthgenhatch, but I have a Sparco steering wheel and it is installed basically the same.
If you have a factory steering wheel on it now pry the H emblem out of the middle. There is a large nut under it. I think it is 19 mil. Take that off and pull the steering wheel off, no puller necessary. Just make sure the steering wheel is straight when you pull it off and you should be fine.
I'm RICK JAMES, bitch!
Use a pick tool on the corner of the H and pull it off, use a I think 19mm deep socket with extention and remove the lock nut then pull off the wheel and do the reverse to install, easiest thing I ever did.
for that added pep
sweet i thought i needed a puller, every other car ive put one in i needed one.
cool thanks for the help guys, and BTLFED it wasnt only to forthgenhatch thanks for the reply
