1stGenCRXer- DCOE question
GWAKS- Tech Geekifier
It's a TWM manifold that came in a Redline Weber kit from www.carbs.net, so I don't know the manifold part number, but you can order the manifold directly from TWM, it is listed as "for FI heads only." Which makes sense because it's for the non-CVCC head, which were fuel injected in this country.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
That's what I'm here for
Looking at some DCOEs?
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Ah yes...
Well, as you mentioned, Pierce makes a manifold, but I've only ever messed with TWM manifolds, which need a little massaging with a die grinder to match up to the intake ports [aka, best done with the head off the engine], and to the carb bodies [I used the softmount gaskets as the guide actually].
As for linkage, you may be able to call up the guys at Carbs Unlimited and see if they could sell you just the kit linkage. I like it more than some other linkages I've seen because it's a down pull style, a plate bolts to the bottom of one of the carbs that has a cable guide and the cable goes up to a barell lock in between the two carbs. The other linkage I've seen bolts to the valve cover [and can use the stock throttle cable], which I don't like because DCOEs were meant to be soft mounted, so how great can the linkage be if the carbs are bouncing and the linkage points aren't? The downsides are that you need an aftermarket throttle cable [I'm using a shortened MGB throttle cable with a modified plastic guide at the firewall] and I have noticed, with the down pull style linkage is that I'm only getting around 85-90% throttle, which is ok for street use, but I still need to look in to how to get some more pull on the cable for the days I use my car for competition.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
No I haven't, although I do have to say it seems to be much more complicated than it needs to be. The two I'm referring two both use a direct connection of the cable to an arm mounted to the throttle shafts. Although that seems to be a linkage setup for cars with limited space, I also have to say that if it works, it works :dunno:
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Originally posted by 2old_honda
any pics of the setup you were talking about?
http://linus.highpoint.edu/~hleach/c...ancinglink.JPG kinda big, which is why I'll just post the links
http://linus.highpoint.edu/~hleach/c...lefirewall.JPG I'm not using that throttle cable any more, but I'm still using the same modified grommet in the fire wall. I was using that teflon sheathed throttle cable from kart racing, but due to the angle the throttle cable pulls inside the car, it would eventually eat through the sheath and start hanging a bit. I'm now using a steel sheathed throttle cable that was made for an MGB, but I've shortened for this application. Works very well, 7 months and zero problems.
http://linus.highpoint.edu/~hleach/c.../returnsp1.JPG I've also added this wheel with an extra return spring, I didn't like the slow decel of the engine without this extra spring. Currently I'm not running the air box, so the other end of the spring is attached to a fabricated sheet metal bracket that attaches to the top air horn stud and comes down to about the mid point of the carb body to provide a straight pull on the spring.
http://linus.highpoint.edu/~hleach/c.../carbsman2.jpg and here's the pic of the bracket on the bottom side.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
