Quick question ?????????
Rotorphile.
Originally posted by deadlock2k1
how would you go about with the oil lines and etc.. i mean i have heard its almost bolt on..(the head to the bottom end from different models)
The VTEC engines also have their head dowel pins on the opposite side of the deck then Non-VTEC engines, so the VTEC head must have the 9mm holes opposite their 14mm dowel holes reamed to 14mm to accept the dowel pins on the same side as a Non-VTEC block.
The standard PR4 Non-VTEC head gasket is used for this build.
Originally posted by crxb16er
its just the base model integra ls gsr and type r are the different ones u can get
RS: second and third generation base model.
LS: second and third generation middle model, became the third generation base model around '99.
LS-S: second generation, slight upgrade over LS.
GS: second generation premium model.
SE (Special Edition): premium third generation.
Since the "LS" is the most common Non-VTEC Integra, this trim level designtion became a nickname for the engine.
