View Poll Results: What area are you focusing on the most?
Engine Power
16
64.00%
Suspension/Handling
5
20.00%
Braking
0%
Car Race Prep (i.e. roll cage, find sponsors, etc.)
4.00%
-to be added later-
0%
Improve the Cars Looks
4.00%
-to be added later-
0%
Road Track Driving Skills
2
8.00%
Drag Racing Skills
0%
Nothing
0%
Voters: 25. You may not vote on this poll
Year 2003 Car Plans (Pre-1992 Civic/Crxs Only)
HC Racer H5
Please try to post plans into one single post (go back and edit if you want to make changes or add things)
What goals/plans do you have for your car and any car related personal goals (i.e. getting competition racing license, getting to your first drag race, or learning how to install an amplifier, etc.) in 2003?
For the poll select what area you area of the changes are you going to change the most...
GWAKS- Tech Geekifier
Well... for my car in the next year I hope to:
Get a full suspension put on the car, Tokico or Koni adjustibles, 27mm Torsion bars, and some 450 # springs in the rear to get the car about 3/4" lower. Also plan to pick up a couple sets of tires, with either Kuhmo 712's or some Azenis for daily tread.
In the engine department I hope to get a custom grind cam done this summer to bump the power output up another 20 HP or so...
If everything else goes well, I'll get all new body work to replace the degraded and cracked factory pieces and a new paint job.
Still on the wish list [get there sooner or later]: Some competition seats and maybe a 6 point cage with removable door bars, with the accompanying 5 or 6 point harnesses.
Also, hopefully in the next few weeks I'll re-do my entire throttle pedal to be able to get full throttle movement [discovered over the summer that the most I can get currently is about 85% throttle].
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
My plans include the following:
1. My Junkyard turbo. Piecing it together and getting it installed. Which has turned out to be a small chore, but worth while.
2. Suspension. Nothing special, just some new shocks and a pro-kit.
3. I'd like to get a little bump in the trunk and install a set of 8" subs. Nothing big, or for competition, but something more then what i got now.
That is really all on the car. I hope to buy a house this next fall, so I can't put a TON of money into the car. Priorities are in order!!!
I'd like to hit the drag strip once this summer. Even if the times will be skewed (5200+ft altitude), it'd still be nice to have some #'s to go by!
Guest
Posts: n/a
#1 install weapon r coilovers (already have them)
#2 install kyb GR-2 shocks (already have them)
#3 install 95 civic si seats (already have them)
#3 get new rubbers
#4 b16a or zc (saving up for)
#5 bondo and primer car
#6 nighthack black pearl paintjob
#7 **** with some gsr
can a civic with a zc hang with a gsr?
#3 get new rubbers
HC Racer H5
My plans for my rex:
#1 goal is to replace the whole suspension:
-hyperflex bushing kit
-front radius arm bearings and tie rod bushings
-upper and lower ball joints
-prothane rear trailing arm bushing
-KYB-AGX adjustables with Race edition Ground Control Coilovers
-Front and rear stabilzer bars, front and rear strut tower bars, and rear toe link bar
2ndary goals are to get it running well and enjoy the car until the next year
For me:
take at least 6-7 road course driving lessons/schools to get more experience
For me:
I'm RICK JAMES, bitch!
Here are my plans:
FIA approved racing seats w/racing harnesses
welded roll cage
seam weld entire frame
new rear suspension bushings
rally computer
mudflaps
roof scoop
paint job
real coilovers
new front crossmember
rewire the engine
put the plastic back in the fender wells
I'm making a rally car out of my crx if you can't tell already
Rob
welded roll cage
rally computer
mudflaps
roof scoop
paint job
real coilovers
rewire the engine
Rob
