piston ques
piston ques
ah will the gx piston and ls rod setup fit a a6 motor???? also i heard that a b serries tb will fit a d serries intake manifold ???? i think it was 92+ any reasons why only 92+ thanks alot
GWAKS- Tech Geekifier
Generally speaking, when you start trying to put internals from one engine series into another engine series, you're in uncharted territory, and on your own. Time to start looking over spec sheets and contemplating the feasibility before going out and buying all the parts...
As for the TB, Honda throttle bodies swap around pretty easily, but the truth of the matter is that aftermarket is readily available for most cars, and so it's not really worth the trouble to find another stock TB that will swap over, but that's just MHO.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
