i dont know what happened
Old 12-08-2002, 09:11 AM
DOD
tool
DOD's Avatar
Default i dont know what happened
ok, yesterday i was out at the mall doing some christmas shopping, i got in my car drove, when i pulled up to a stop sign it just died, my radio shut off, turn signal quit blinking, and the clock went out, but i could still turn the motor, it just would start. i got out and checked for spark and it had none. i got back in the car took my cd player face off, with the ignition still on. as son as the face came off all power came back. it started right back up and i drove home with no problem. does any one know what happened here??
oh this was in my 88 hf
Old 12-08-2002, 04:10 PM
Guest
Guest
Posts: n/a
Old 12-08-2002, 04:39 PM
WhiteRice
WhiteRice's Avatar
Is your cd player hooked up correctly?? Is there a loose connection that might cause a short when turned on?? Or was taking off the face just a coincidence?
Old 12-08-2002, 04:45 PM
Deludedteg
Deludedteg's Avatar
Try putting your faceplate back on and see if it does it again.
Old 12-08-2002, 05:56 PM
FourthGenHatch
I'm RICK JAMES, bitch!
FourthGenHatch's Avatar
No spark would be distributor. However a similar thing happened to me before while I was driving my CD player died (not the car). Later that night my Alternator went up. So beware.
Old 12-08-2002, 06:05 PM
WhiteRice
WhiteRice's Avatar
IF it is your dizzy, check your cap/rotor,and your ignition coil.
Old 12-08-2002, 07:42 PM
AwwsChwA
AwwsChwA's Avatar
it's wierd that even your blinker quit working. That means that not only did the ignition die, but the electrical system was shut completely off. Sounds to me like there's a loose wire somewhere in your stereo system, and its causing a strong enough short to shut everythign down.
I agree with ForuthGenHatch, watch your alternator. Unfortunately Honda's are very prone to electrical system damage with even minor shorts.
Old 12-08-2002, 08:06 PM
DOD
tool
DOD's Avatar
i tried driving it again tonight. it was fine untill i put the cd face back on then it died again. but this time when i turned it back off the car wouldnt start back, i let it sit for a whil ethgen tried it and it started up. i m gonna try to look at it tomorrow thoug, thanks for the suggestions.
Old 12-09-2002, 03:25 AM
excitid
excitid's Avatar
do you have amps hooked up also or just a stereo
Old 12-09-2002, 11:57 AM
BlackCRX
BlackCRX's Avatar
like everyone said, check all the wires in your system
make sure all the grounds go to ground and all the power goes to power
if you have amps and stuff remove one at a time and see which one is causing the problem
