1992 B18a/b into 89 DX hatchback??
Old 12-04-2002, 06:10 PM
1stGenCRXer
GWAKS- Tech Geekifier
1stGenCRXer's Avatar
No, an OBD ECU reads only engine and VCC sensors. It relies on water temp and vehicle speed to determine whether or not to turn on VTEC. Doesn't care about braking, doesn't care what gearset is in your tranny...
-Harry
AIM: NDcissive
Old 12-04-2002, 07:52 PM
Speed Phreak
Turbomafia
Speed Phreak's Avatar
Originally posted by FourthGenHatch
You also need to convert to ODB-1 if you run a 92 Integra engine since they went to ODB-1 starting 1992.
Why? It'd be simpler to just drop in 88-91 Si or 90-91 fuel injectors. and a 90-91 distributor........and then use the 90-91 ECU. Plug and play is much simpler for first time swappers than going through the wiring hassle of converting to ODB-1.
