rack and pinion
Old 01-05-2004, 10:05 AM
excitid
excitid's Avatar
Originally posted by allbutjdm
My boots on steering rack are also leaking.. would this cause all the wobble and clunking that i am having in the front when turn to the left? (97accord 4cyl) everytime i hit a small bump i feel it.. when i turn left slightly at high speeds, i hear a whole mess of clunking and wobbling... anyone shed sum light on this? should i change the rack? and what else? anyone done a rack on a 5th accord? any info/tips will be apprect'd.
thanks,
jerrry
I would have all of your front suspension checked out. Start with your tie-rods ball joints check you axles and also your upper control arms. It could very well be your steering rack but I would check out the other stuff because a failure of most of these parts will cause much bigger headaches later. We have a 94 accord and its a bit wobbley but an alingment and new tie rods should help if its not one of the other things mentioned.
