zc.. NO SPARK.. help!
hey guys can you gimmie some ideas on what to check.. just put a zc into a 90 si and all the wiring is right from what we've read.. but were not getting any spark. also all grounds are connected as far as i know..
help!!
help!!
Click here for Cap/rotor check
To check the igintor, goto www.quickhonda.net There will be a list of links on the left. GO into....Garage...then Electrical service manual...then scroll down, you'll find some stuff on the ingnitor and dizzy... It'll show you exactly what the ignitor (ignition coil) is and how to change it. It's about 80 at Autozone. I'm sure you can find one cheaper at a junkyard. But if it doesn't work, just take it back. It won't get dirty or anything. I'll check a little later to see if I can access the page.
