Rear damper removal
Rear damper removal
I'm tryiing to get the rear dampers off my 91 HB.
I removed the nuts in the hatch, and the bolt on the control
arm.
I can't seem to get the assembly out. Is there another bolt I have to remove for more clearance?
I try stepping on the drum but I can't get it down far enough.
It's kinda hard by myself...
Is that the right procedure?
arm.
I'm RICK JAMES, bitch!
Unbolt the LCA from the Trailing Arm and just pull the whole strut/spring assembly down (supposing it was also unbolted from the top part and the LCA).
Thanks. Thanks what I did
In my manual it just says to undo the top bolts and
the LCA bolt. Maybe I'm missing a section, It's a copy
in pdf...
ANyway, I'm finished and the drop looks great. I'm real
happy with it.
Thanks for the help
in pdf...
happy with it.
Thanks for the help
