???crx sputtering stalling and intemittant smoke
hey everyone just to let u know this site is awsome and helped me alot in lots of areas now on to the bad
my car had a timing belt issue and its now fix i had replaced the head gasket and routine matinice well the car now starts fine idels ok then when i got to drive like 2 min later its starts dieing and missing cant go fast cant rev have to take it slow it jerks then latr it starts smoking alot then worse but then clears up and its fine ike for a min then back and forth and so on would this be a timing issue still or spark timing issue i pulled the plugs and three of four look ok and one doesnt look fresh and had smoke coming from spark plug hole could this be fuel build up and fouling or somthing i checked the dist modual its ok any info please????? thanks zac
did u take off the intake manifold at all, what color is the smoke, it could be oil or antifreeze burning something could be seeping on top the the piston and cause the sputtering
