engine swap woes..
engine swap woes..
hi guys. i bought a crx for 200 bucks. its a peice. well anyways i wanted to do an engine swap. i have 2500 bucks saved up to do it. i got a jdm b16a cable tranny i can use. so i decided to do a b18a swap. what else would i need to do this swap? integra axles ? 90-91 integ engine? ecu, hasport shift linkage? motormounts?
also i can geta b18b for about 800 bucks. but i need t oconvert it to non obd? how do i do this?
thanks everyone.
thanks everyone.
need more info than you gave us...what model and year crx is it?...depending on what model tells us if you will have to do some wiring or buy a conversion harness and whether you will have to change out the front knuckles to fit the stronger b series units
if you search this forum there are links and info on these swap questions and you'll find most answers there
for the price of converting a b18b to non obd i dicdied why not just go the way of vtec? so i chose the jdm b16a. i am probably going to order from hondamotorsonline. how much is this engine swap gonna put me back? if i get new radiator, hasport **** and clutch? and a vfac? any b16a guys out there? what did you guys run? mods ? who did the swap? HOW MUCH DID YOU PAY?
THANKS
THANKS
