oil pan drain bolt
oil pan drain bolt
in changin my oil yesterday i found some tape on my drain bolt... when i went to put the bolt back in i realized that the pan threads were stripped and the bolt would not tighten all the way.. so i realized that whoever did the last oil change put that tape there to seal it and keep it tight.... what is my best way to make a fix on this???
Drain Bolt
Well you could retap the bolt hole and screw around with it... but easiest method is to put a new pan on... If ur strapped for cash you can use an oil safe sealant, seal the old bolt in place and replace it in like a week but I would recomend going to honda or a scrap yard and picking up a new one. (oil pan that is)
I would definitely get a new pan. It's not worth risking the engine. I work at a dealer and I see cars that people have taken to independent shops and they strip the drain plug on a daily basis, the only real permanent fix is a new pan. My local NAPA shows it for $80
