I need help with clutch install
I just bought a new clutch for my wagon along with all the seals for the gear box along with a new rear main from honda. I also got redline oil for the gearbox. I need to know if the clutch cable is a self adjusting or does it need to be adusted after new clutch install. I have a helm's manual on order but I can't wait that long. The flywheel is at the machine shop already
Thanks in advance
Thanks in advance
Re: I need help with clutch install
Thanks in advance
Thanks in advance
as for adjusting the clutch...i'm not sure honda had a self adjusting cable clutch...adjusting its a breeze anyway...find where the cable goes to the tranny and adjust the plastic item until the clutch is taught...then get in the car to see if it feels ok...if it is take it for a drive and see where it engages...then do 2-3 turns each small adjustment then with test drives until you are satisfied
