HELP!! How do I tell what tranny I have
Don't ask.
I got a tranny from a shop that said it was a 91 civic Si. I got axles from a 91 civic si and the shafts that go into the tranny are too small. What axles will fit? And, where can I get them?
if the axles are too small where they go into the transmission, then you have a ZC transmission - the JDM ZC transmission uses the JDM ZC intermediate shaft and 90-93 Integra axles - the Integra axle will work on the passenger side, but without the intermediate shaft on the driver's side, there is no axle available - you would need to have one custom made
Don't ask.
Thank you for the info! Would the intermediate shaft from an Si work? Also, I have the drivers side axle from 91 Si, the passenger side axle from a 91 integra and the passenger side from a 90 accord. The transmission side splines look almost identical on the teg axle and the accord axle, would they work? Could I take the spline off of the accord axle and put it onto the Si axle and use it that way? I have done this before with my old Ford probe and it worked great, but those were two of the same axle.
