white smoke coming out from muffler
Old 06-10-2007, 11:56 AM
93hondablk
TheOtherJesse
93hondablk's Avatar
Default white smoke coming out from muffler
theres white smoke coming out my muffler from my crx so that means that i'm burning oil?
Its also making spitting noise when i give it gas.
Old 06-10-2007, 01:16 PM
daddiodanger
bad mo fo
daddiodanger's Avatar
burning coolant, bad headgasket
lacks power, cause water doesn't combust all to well.
Old 06-11-2007, 11:48 AM
mberndt
mberndt's Avatar
No, Oil burns blue...
Coolant burns white.
Sputtering means there is moisture or water in cylinder...
Best bet is headgasket is done for.
Old 06-11-2007, 12:57 PM
94civicEX
I got worms.
94civicEX's Avatar
Ditto on everything said above.
99 Integra GSR
06 TSX
duck squad member #00003
Old 06-12-2007, 08:08 AM
93hondablk
TheOtherJesse
93hondablk's Avatar
damn good looks I'm taking to the shop today then, I was just going to let it run like this for a few months....p.s what if I did drive it like this for a few more months blown motor?
Old 06-16-2007, 04:15 AM
m735is
m735is's Avatar
Depends on how long the gasket holds and how much coolant you're loosing.
It would be cheaper to have the gasket done now before you overheat or blow the entire motor.
My son drove his for a couple of weeks with a leaky radiator. Then the car overheated and the gasket failed. He needed a tow home. It was winter time and very cold, so I just replaced the radiator,head gasket, intake gasket and exhaust gasket. Only took me a couple hours. Although I had just replaced everything else a year before (timing belt, water pump etc) so I knew that stuff was good.
Is there a reason you are trying to hold out for a couple months? New swap, new car maybe??
Old 06-16-2007, 09:12 AM
93hondablk
TheOtherJesse
93hondablk's Avatar
I went to the shop and they didn't see anything wrong. All they said is that I can use a tune up
Old 06-27-2007, 03:39 AM
bluevette1978
Don't ask.
bluevette1978's Avatar
Did they do a pressure test on the cooling system and a compression test? As long as you told them white smoke from the exhaust, they are complete idiots if they didn't.
I could figure that one out even if I wasn't Master certified...lol.
Old 06-30-2007, 03:32 PM
daniel9111
SiKid
daniel9111's Avatar
hey i have a question my friends car is smoking... he when to the shop and they told him that blue smoke was comming out because something was wrong with the valve and they needed to replace the valves...so do you think thats the problem......or he has bad piston rings....
Old 06-30-2007, 07:56 PM
theleprechaun
theleprechaun's Avatar
Default The Valves...
If a valve leaks that means oil can get into the cylinder from above through the head, if its the rings it gets past from the piston... So if they say he has a bad valve its probably the valve seat (seal?) I believe, should be a lot cheaper than replacing the rings, as its a hellav lot more accessible.
