Time for the big swap B16 Sir into 88 Crx Si
Old 01-16-2007, 04:03 PM
88crxTurbo
Clean and Simple
88crxTurbo's Avatar
Default Time for the big swap B16 Sir into 88 Crx Si
Alright guys, I talked to Hmotorsonline.com, I priced everything im going to need, and it will be coming to me here in a few weeks once i get the rest of the money together. I have just a few odds and ends that I want some confirmation on when installing. I have researched and understand what I am doing very well, my brother and I are doing the swap, and he is the "Certified Honda Mechanic." purchasing a B16a Sir motor OBD0, with lsd 5 speed tranny. the axles I am putting into my car, do they have to be custom, or can the axles for a b16a work for my car.?? once again I am driving a 88 Crx Si. The engine will be turbo right off the bat, so I have also acquired a turbo manifold and other goodies. yes I am running a piggyback computer, greddy emanage to be exact. the downpipe for my turbo on my previous motor was always interfeering with my front crossmember, is there anyway to avoid this? hack and reweld supports, or if i bought an aftermarket crossmember made of tubular steel, would that supply enough room for my downpipe off the turbo so it wont interfere. any pictures would be greatly appreciated. also what size downpipe, and exhaust should I use for best efficiency, running around 8-10 pounds of forced induction fun?
Old 01-16-2007, 09:52 PM
pinkb18crx
Mr. Honda
pinkb18crx's Avatar
Ok the axles should work as long as they are from a b16 powered ef (88-91) civic/crx or a 90-93 integra. Remember the integras got b16's in the xsi. As for your crossmember you can hack it up, my buddies did this on thier b16 turbo'd rex and they are now buying an aftermarket one. Inovative racing sells one for 200bucks that allows you to run the 92-95 civic half size radiator which is a great investment if your going turbo, clearence issues with the bigger full size ef radiator. The inovative crossmember is already designed to fit a turbo mani and downpipe as well. My buddys are running a bone stock b16 with a t3/t4 tuned at 7psi pushing 240hp to the front wheels.
Old 01-17-2007, 12:53 PM
88crxTurbo
Clean and Simple
88crxTurbo's Avatar
Awesome. can you get me some pictures of your buddy's setup in that crx mainly the downpipe and charge pipe setup off the turbo. Thanks for the help.
can i get those axles locally from an auto store? or are those a bit harder to come by?
Old 01-17-2007, 03:57 PM
pinkb18crx
Mr. Honda
pinkb18crx's Avatar
Yeah you can get them at local autopart stores just use 90-93 integra w/o abs
Old 01-17-2007, 05:05 PM
88crxTurbo
Clean and Simple
88crxTurbo's Avatar
okay, thats good to know. thanks a lot for your help. I will hit you up if I have any more questions about the swap.
Old 01-17-2007, 06:00 PM
pinkb18crx
Mr. Honda
pinkb18crx's Avatar
The axles are 65.99 for driver side part # 026403 8000 for driver side, 59.99 for passenger side part # 026406 8001 @ autozone! thats after core charge of course, but hell you can take them your stock civic axles they dont know any better. I took 1 eg axles and 1 accord axles for my cores!
Old 01-18-2007, 01:12 PM
88crxTurbo
Clean and Simple
88crxTurbo's Avatar
Very good. Thanks for the info. one more quick question, what can these b16 sir engines hold STOCK in the way of boost? how many lbs? and how much HP?
Old 01-18-2007, 02:01 PM
pinkb18crx
Mr. Honda
pinkb18crx's Avatar
My buddys stock b16 is only pushing 7 lbs of boost but putting out 240hp to the front wheels. I would say you could prob get 10lbs safely out of a stock b16, the rods arent as strong as the stock LS rods, thats the only downfall
Old 01-18-2007, 03:42 PM
88crxTurbo
Clean and Simple
88crxTurbo's Avatar
okay, yeah thats what I was thingking. I was shooting for close to 300hp for my track days. but lower for normal driving, I already have the boost controller.
Old 01-19-2007, 07:47 AM
nathancrx
nathancrx's Avatar
actually its the ringlands on the pistons that are the weekspot. with good tuning 300 is obtainable.. look into some alky or water injection to keep detonation down and you should be fine..
