I can go up to 10 mph at idle while in drive. What is the problem?
Old 12-03-2006 | 01:33 PM
thebassn8tr's Avatar
thebassn8tr
Default I can go up to 10 mph at idle while in drive. What is the problem?
I have an 89 civic DX automatic, all stock. When I am at a complete stop all I have to do is let my foot off of the brake peddle and the car goes up to 10 mph. Normally a car would just sit there and idle until you apply a little gas. What do you think that the problem is?
Old 12-03-2006 | 05:49 PM
ReVenGe's Avatar
ReVenGe
automatics go foward unless you step on the brakes.
Old 12-03-2006 | 05:54 PM
AJ˛06's Avatar
AJ˛06
Its always been like that... h:
Old 12-03-2006 | 05:59 PM
ReVenGe's Avatar
ReVenGe
aparantly not evenone knew that :dunno:
Old 12-03-2006 | 06:00 PM
Misa's Avatar
Misa
Pic Whore
whats your idle rpm in neutral?
Old 12-03-2006 | 06:24 PM
jaje's Avatar
jaje
HC Racer H5
Most older cars had automatics that would allow the car to creep along (usually 4-8 mpg) unless you had your foot on the brake. After many accidents by inattentive drivers leaving their car in gear and getting out (people are stupid and we must them and ourselves from the stupidity), most make cars now that have eliminated idle speed meaning you have to push the gas to move the car (most of these are minivans, etc.).
As Jani noted if your idle is too high (should be around 600-900 rpm when warm) your idle speed will be faster.
Old 12-03-2006 | 06:30 PM
thebassn8tr
I don't have an RPM guage. As jaje stated it will only let me go up to 10 mph then drops to about 6mph then goes back up to 10 mph. Must be normal. It just feels like the car wants to take off once I take my foot off the brake. But as mentioned, it never goes above 10 mph.
Old 12-03-2006 | 09:44 PM
Snoopy's Avatar
Snoopy
been there done that
keep your foot on the brake or put it in park/neutral. problem solved. :dunno:
Old 12-05-2006 | 09:55 PM
daddiodanger's Avatar
daddiodanger
bad mo fo
i agree, idle might be a little high. the stall speed of the converter was probably pretty low in that year.
Old 12-06-2006 | 12:08 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Only problem I hear in your scenario is that you have hardly any friction in your wheel bearings and brakes when they're not applied...
Which isn't really a problem
-Harry
AIM: NDcissive
