clutch
Old 12-06-2006, 04:06 PM
88'CRX
88'CRX's Avatar
ok im pretty sure i got the trans that comes stock with the b18a1 motor..but how could i tell other wise??? and searching online i found this clutch kit http://www.andysautosport.com/acura/...t00041459.html would this be a good setup or even a good brand?? and also does it look right that this one is cheaper than the others if you go back and look at the other ones of this brand on the website???
Old 12-06-2006, 04:18 PM
18crx
stock booster
18crx's Avatar
ok u need to know what year the trans is if its a 93 or a 90 if 93 it has a diff amount of splines on the input shaft
Old 12-22-2006, 08:01 AM
88'CRX
88'CRX's Avatar
splines on input shaft??? where is this located ???im not sure i know what you are talking about and does anyone know how many splines are on what year trans??
Old 12-22-2006, 11:37 AM
18crx
stock booster
18crx's Avatar
wow ok its the shaft that goes into the trans from the clutch disk. you have to remove your trans to find it.
Old 12-22-2006, 04:34 PM
88'CRX
88'CRX's Avatar
rite so how many should what year have ??
Old 12-22-2006, 10:16 PM
18crx
stock booster
18crx's Avatar
93 and up are 23 splined
Old 12-23-2006, 07:21 AM
88'CRX
88'CRX's Avatar
are you sure its not 92 and up because the clutches are sold for 90-91 or 92-93
Old 12-23-2006, 08:29 AM
18crx
stock booster
18crx's Avatar
well i know mine is a 93 and it has 23 splines not 100% about 92 but probaly the same, ill look and see if i can find some more info.
