What parts from an integra will
EM1 Crew member #74
fit the crx? I have a 91 crx hf and i just picked up a 92 integra. I will be swapping the motor and trans and ecu, rear disc conversion, front disc, maybe even the rear sway bar. What else can i use from the integra that would be better on my crx?
You will probably have to get the ASR rear Subframe brace to fit a larger sway bar on it, but I am not sure if ASR makes one for the CRX. Not a WHOLE lot that you will realy want to swap into it though. You might as well jsut swap what your going t oand save the car for parts or part it out. Make sure you run those wires for VTEC.
