what is this sound
Old 11-03-2006, 02:29 PM
90_crx_flaze
Drift King
90_crx_flaze's Avatar
Default what is this sound
i started up my ls vtec today and noticed a sound exactly like this http://media.putfile.com/1995-Integra-GS-R-Engine-Sound The car was fine when i parked it it started up just fine and it has a chattering sound like a bolt or something fell in the head. it runs fine throws no codes compression is fine but it sounds annoying and this motor is brand new, i have it for the daily driver and havent been hard on it at all. when you rev the car it goes away and comes back dont know if it goes away when the car is warmed up i heard that sound and shut it off. could this be the water pump or something near it, its sounds like its on the intake side.
Old 11-03-2006, 04:01 PM
Fuse
Fuse's Avatar
try tightening your belts first if it will not go away take off you belts if it gos away you might have a bad alt, p.s. pump, ac.if it is still ther with the belt off water pump, t belt, t belt tensioner.let ne know
Old 11-03-2006, 04:04 PM
90_crx_flaze
Drift King
its not the squeeking sound its more of the ticking sound almost like a knock but im pretty sure its not.
Old 11-03-2006, 04:06 PM
90_crx_flaze
Drift King
the timing belt has a little pay on the front under the exhaust cam but its not flapping or anything
Old 11-03-2006, 04:07 PM
Snoopy
been there done that
Snoopy's Avatar
have you adjusted the valves?
Old 11-03-2006, 04:38 PM
90_crx_flaze
Drift King
hmmm i havent done that since we put the vtec head on the ls block it has GSR cams in it
Old 11-03-2006, 06:17 PM
Snoopy
Snoopy's Avatar
you need to adjust the valves
Old 11-04-2006, 12:00 AM
latinracerct
latinracerct's Avatar
mine did the same ls and sorry to say had a bad rod sent a piston through the block!
Old 11-04-2006, 12:44 AM
Hondelso
Hondelso's Avatar
well are you using new pistons? vtec pistons are DIFFERENT than a non-vtec piston. it's better to use vtec pistons it's a lot easier to get proper clearance.
Old 11-04-2006, 06:20 AM
90_crx_flaze
Drift King
there is no rod through the block, i pulled off the oil pan and took of the baffle cover thing and everything looks fine from below i turned the crank as i looked the rods arnt bent or broken the car has fine compression!
