88-91 crx side marker install. HELP!
i
I recently got the 88-91 EF CRX sidemarkers for my 1988 CRX, however I cant find a template to use. does any one have one??
below is a picture of it currently.
2 tone Rex
Heres the measurements so you can make your own... You can draw it out on a white label type sticker and stick it on the car (thats what I did)...
http://www.jdmuniverse.com/forums/sh...ht=side+marker
Tip: I found out that it dosnt have to the the exact shape either... As long as you notch it just right they will slide in and stay in... And use alot of tape in the surrounding area (to help protect the paint incase you slip)... Plus it helps prevent cracking the paint...
