Grrr... Transmission
Old 10-16-2006, 04:12 PM
MTEng
MTEng's Avatar
Originally Posted by racerdave
The car shifts into gear when it is off. But when I start it up, and try to shift it into any gear it just wont go into gear, I dont want to force it. The only gear it will try to go into is reverse, but it just grinds away.
classic symptoms of a bad pilot bearing
Old 10-16-2006, 08:11 PM
Line7
Platinum Member
Line7's Avatar
sorry dude, i didn't realize that....
Old 10-16-2006, 08:13 PM
Line7
Platinum Member
Line7's Avatar
Two words - Cable Transmission.
.... Sorry dont meen to be a smart @ss, its just everyone that I told my problem to, said its the slave or master, before I even spit out my symptoms.....
In my first post I said I have a Y1 Cable Transmission.
Thanks tho.
Sorry dude I didn't realize that.
Old 10-16-2006, 09:43 PM
racerdave
USAF C-17 Crewchief
racerdave's Avatar
Its all good.
I talked to a few local shops. And I put the car up on stands and messed with it.
Turns out, everyone is 99.8 % sure its my pilot bearing, I had my buddy look at it and when we put it up, and turned the car on, the wheels slowly started to spin... So yea
Thanks for all the good info again!
5$ Pilot bearing at the local parts store tomarrow should fix it.
I had this thing all apart once.. Now I have to tear into it again! GRRRR....
Oh well, Im a pro at it now ;-)
Old 10-18-2006, 06:02 PM
racerdave
USAF C-17 Crewchief
racerdave's Avatar
So.................
Turns out the pilot Bearing is fine...
This was the problem :
...... Yeah, so... New clutch is on its way.....
Only thing that it did to my flywheel was shave a small spot off of each flywheel bolt head (nothing to worry about).
So... What would cause this? Is it just a faulty clutch disk?
It has no part numbers on the disk, The pressure plate is ACT, but im not sure if this disk is ACT or not?
The one that I found online from ACT has 6 springs. this one has 4....
So...
Any ideas?
Old 10-18-2006, 06:43 PM
MTEng
MTEng's Avatar
That could certainly cause the problem I've seen a handful of disks let go like that when they get near the end of their life. May be from abuse (dumping clutch) or that's just what decided to let loose first. I'm not sure it's that uncommon. That disk looks like it has a few miles on it.
Disk looks very OEM... but who knows.
So silly question... but you didn't notice that "missing" spring when you ripped it apart (post #1) ?? Just curious....
Old 10-18-2006, 07:01 PM
racerdave
USAF C-17 Crewchief
racerdave's Avatar
Haha, yea, I didnt notice the missing spring because from the other side, everything looks perfectly fine.
I never took off the presure plate and inspected the clutch, I was told to replace the throwout bearing, and also didnt have a clutch alignment tool to put it all back toegether... So just decided to call it good...
Big mistake...
From now on, its in depth inspections every time...
Old 10-19-2006, 06:33 PM
90_crx_flaze
Drift King
90_crx_flaze's Avatar
ha ha i knew it my clutch got stuck engaged the same way when i came off the highway the car kept pulling forward, i got it to disengage by dumping the fuck outta it but it locked back up after a few gear changes
Old 10-21-2006, 04:55 PM
MTEng
MTEng's Avatar
Bet that loose spring looked like hell when you took it out ... hahaha
Old 10-21-2006, 06:44 PM
90_crx_flaze
Drift King
lol my clutch was the same color but the springs were more like cylinders and the missing peice was nowhere to be found i woulda beat that damn ls integra if my clutch was in, bastard. he said i had a sad excuse to lose, then i got next to him and pulled out of the back of the car my new clutch pressure plate and flywheel, havent seen the guy on the street since, come to think of it i just got some read discs off a car that looked exactly like his!
