My Vtec crapped on me
Old 08-14-2006, 08:37 PM
honda_76401
honda_76401's Avatar
Today I pulled the vtec noid off the engine and cleaned it out with brake cleaner and put it in the vat at work for awhile to clean it out. I put it back on and it stills makes the exhaust note change but no umph at all. We put it on my friends b16 powered hatch and the noid didn't work on his either. So I was thinking maybe just the noids busted but I put his working vtec on my motor and ran it and it didn't do anything different. I have no idea what the hell the deal is, no CELs,good oil level, wiring is correct, warm engine. I'm starting to think I shouldve just paid the extra money and bought this motor from a company. Well tell me what you think. Thank you all
Old 08-14-2006, 09:01 PM
Exempt
2 tone Rex
Exempt's Avatar
Only thing I can suggest is, hook a test light upto it... If it lights up, the ECU is sending the "all good" signal and VTEC is engaging... But if theres no noticable power, the solenoid may be bad... Then again, a bad solenoid wouldnt change the exhaust note... Honestly tho, it sounds too me like your not used to the VTEC crossover and just dont notice it yet... Its not like hitting mad NAWWWZZ power band y0! On a perfectly tuned engine, you really shouldnt feel much of anything at all (meaning the cross over should be nice and smooth), except your RPMS will start to climb really fast...
Old 08-15-2006, 04:10 AM
av0
EF9 SiR
av0's Avatar
Which ecu are you using? Upgrade to OBD-1 if you have some spare time and money. Maybe invest in an Ostrich and a Crome Pro license. If it makes the sound than the solinoid has successfully transfered into the High Cam profile.
I'd check your timing to see if its retarded a bit. Go a little further and get oil and fuel pressure gauges and see what you may or may not be pushing out.
Old 08-15-2006, 09:41 AM
honda_76401
Thanks for the help. I'm running a pr3 ecu on this one. LOL I know it's not some fake ass fast and the furious like boost, this is my 3rd honda with vtec and its not hard to notice the vtec engaging even on a d16. There is no powerband what so ever on this pile engine. I'm going to hook a test light up to it this afternoon and hopefully figure something out. Thanks for the help once again.
Old 08-16-2006, 06:38 AM
HONDA_driven
got vtec?
HONDA_driven's Avatar
I'm no master tech.. but have u checked ignition curve and fuel map at the crossover point? Maybe there is a pressure drop due to a bad ECU. Borrow someone's ECU to check this theory.~~~when in doubt, use someone else's stuff!!~~~
Old 08-16-2006, 08:14 AM
honda_76401
thanks honda_driven i'll give that a shot too
Old 08-16-2006, 12:00 PM
Nbboy7
Don't Sleep On Me
Nbboy7's Avatar
Check the vtec solinold
Old 08-17-2006, 08:52 AM
honda_76401
I took the noid apart and cleaned it real good. The piston still works good in it and nothing seems to be broken or out of place. I'm still waiting to borrow someones ecu soon to check if thats the problem.
Old 08-17-2006, 09:56 PM
anthony12389
anthony12389's Avatar
the only thing i can say an uve already heard it from other ppl is check the oil level make sure its got enough oil.. an the vtec wiring on the noid an ecu..
Old 08-18-2006, 08:32 AM
honda_76401
I use Castrol syn. and i just changed it like 500 miles ago. I put my friends pr3 ecu on today and have been driving it around town. Still nothing of course, This makes me think its wiring or the motors just screwed up. I'll keep trying. Thanks for everyones help
