Wheels/Tires
Wheels/Tires
What size wheel/tire will fit on a 91 CRX for autocross purposes? I've seen some other CRX's with tires that stick way out past the wheel well.
13" wheels would be ideal but I think I can only go as small as 14" becuase I have integra rotors/calipers. I have no idea how wide I can go though.
Thanks for verifying the 14" limit with Integra brakes. For the width/offset the only limit is what will physically fit on the car.
15.4 WHEELS
Vehicles may only exceed the allowances of 13.4 as specified herein.
A. Wheels of any diameter, width, or offset may be used. Aftermarket
wheels may be modified to install OE tire pressure sensors.
B. Wheel spacers are permitted. Wheel studs and knock-off wheel
drive pegs may be changed in length and diameter. Wheel bolts
may be replaced with studs and nuts.
15.4 WHEELS
