DOHC ZC Compression...
umm..
Not that compresion...like a compression test....is that what it's called...I'm so tired.......I want to make sure it can handle that noz kit......
Direct Port 55 shot kit on a 92 Hatch w/OBD1 92 DOHC NONVTEC ZC motor....
Re: .........
a compression test on a 9.2:1 Honda engine should yield 180- 190psi on a compression test. That's what my CRX yielded (9.2:1), and the Honda place said that was right on target.
The compression readings should be slightly higher than those listed above. The big thing is that there isn't a huge variance between cylinders. I think that the difference between cylinders should be less than 10% or something like that.
Chris
Chris
