crx wont start
crx wont start
I have a 90 dx crx..Last night i went to take the car for a ride cause i didnt start it for a very long time.....THen once i pulled in to my driveway the car just died out..BUt the lights were still on and the radio was still on..BUt the car would not start at all. Its not the fuel pump cause i check.Its not the coil or the rotor or the battery..I still have Gas...But when i try to start it, it wont start at all..It cranks over but its making a noise, It making a popping noise.I change the sparks pulgs,wire.......
Need your help peeps..
Thanks for the time and GOD BLESS
I check the fuel pump it still works...But the popping noise comes from the intake manifold.My friend said my timeing is backward.
TOday i tryed starting it agian it wont start at all..Where is all the main relay in a crx?
THanks guys for all your help......
yea the gas could be a problem.
CHECK:
Spark
Fuel
Timing
Make sure u got fuel coming out of the injectors, make sure you have spark on all 4 cylinders, and make sure the timing belt didnt slip.
Put new gas in it and put in some injector cleaner too!
CHECK:
Spark
Fuel
Timing
89 CRX si, now with b16!
Originally Posted by civicdxx
I no im getting fuel and spark because the car will run when push started. Im pretty sure its electrical because the engine wont even make a sound when i turn the key.
