s2k cluster in my 88si
I know it can be done.But from what i understand the speedo dosent work....so how can i make it to where i have a fully functional s2k cluster in my 88si?
It's going to look kind of stupid unless your car has a B series VTEC and you are using the cluster from after they switched to the 2.2. Or a built one with the older cluster.
Either way, it's going to be a total bitch. I don't even know if the S2K uses a VSS in the cluster like your car does. This is one of many problems you're going to run into.
