91 crx window same as 91 civic????
Im thinkin it doesnt but just going to ask anyway. wondering if the driver side window from a 91 civic will fill my 91 crx??? on off the clips off my rexdriver side window is broke....you know the clip that holds the window and is attached to the bracket that moves the window up and down. if not could i heat the clip a little around the top to allow the factory sealent to give a little??? thanks
the whole window at first but now that i know it wont work. the clips that hold the window i need to know how to get them off i have an extra window with clips on it and i need to replace one of the clips
$30 later i learned this too, now i have a spare crx window that doesnt fit for shyt, luckily i found a hatch window though but yeh anyways i guess you can somehow heat the brackets but aligning them might be a bit hard...
thanks i was thinking about screwing in the bracket setting the window in the bracket then outlining it so when i take it out i can have a good idea of where it goes.
